dex 2,065 Posted February 28, 2017 Hey all ,,, Anyone have a pic of what needs doing to run the fd tail lamps and fuel cap cover into an fe ? . Have read theres some fiddling needed ,,but never seen what . Know boot lid chrome trim needs swapping over to the narrower raised center section . Cheers Share this post Link to post Share on other sites
Free.51 2,717 Posted March 2, 2017 I was running fd taillights in my zl a few yrs back i just angle grinded the rear panel to fit the taillights not a pro job but worked you could probably unpick the rear panel off a zj zk fc fd & spot weld it to your fe after taking off the original one dont forget the wiring & globes which are wired to the tail lamps the light up nxt to the indicators Sent from my LG-H340 using Tapatalk Share this post Link to post Share on other sites
dex 2,065 Posted March 2, 2017 Thought it'd be a hole saw job , As in to open up a hole for the extra light Share this post Link to post Share on other sites
Free.51 2,717 Posted March 2, 2017 I suppose if you had a big enough hole saw,the threads on the taillights are in different locations on fd to fe lights too Share this post Link to post Share on other sites
dex 2,065 Posted March 2, 2017 Ahh ,, Righto ' Anything else to be aware of ,? Share this post Link to post Share on other sites
Free.51 2,717 Posted March 2, 2017 The fuel flap door will fit but from memory i snapped off 1 off the threads so it would fit (youll see what i mean when you do the swap) When you change the boot trim to fd i think youll have a couple of holes exposed from where the fe one was i just kept the fe bootlid which did look a little out of place also are you keeping the fe rear bar or going xe rear bar? I put all the surrounding trim & xe bar on mine Theres some pics of mine in the showroom under "show us ur fairlanes/LTDs Share this post Link to post Share on other sites
dex 2,065 Posted March 2, 2017 Hmmmm , Starting to talk myself out of this now . Didn't realise the bumper would need swapping out as well . My bumper and side trim is in good nic . I thought itd be a simple swap out . + id loose the good reverse lights ,,,,, narrow driveway mine , between brick wall and fence ,,, bout 6 inches either side of the mirrors Share this post Link to post Share on other sites
Free.51 2,717 Posted March 2, 2017 You dont need to change the rear bar, i just did it cos i had it lying around off a zk & it made the backend look like an fd thats all Share this post Link to post Share on other sites
dex 2,065 Posted March 2, 2017 Ahhhhh . Theres one back in the corner Share this post Link to post Share on other sites
