NZXD 2,328 Posted June 4, 2016 ok but the b/w teeth go in the opoisite way ,i found this out in my bw-35 unless the au tranny tooth is on the passenger side ? I had a look ,the au is a left hand tooth so i dont no how long its going to hold up in your box but if it works ,well done,the fmx box have right hand teeth and an extended nose ,where others are shorter. Sorry I was meaning the 1:1 ratio was the same. I run a single rail which has the speedo drive on the same side as an AU auto box. Share this post Link to post Share on other sites
CHESTNUTXE 7,355 Posted June 4, 2016 ok then check your cluster one more time to make sure its all good before putting the dash cover back on. Share this post Link to post Share on other sites
