SLO247 1,713 Posted April 23, 2016 Just fitted an EFI rocker cover to my crossflow. It would be much neater if I could put a t piece in the vac line running across the rocker cover to the booster, and plumb it to the PCV valve at the rear of the rocker cover. Can I do this or nah? Also I was just going to fit a breather filter to the breather at the front of the rocker cover. To get it into the air filter will need two elbows and will look like arse. Is this also a shit idea? I'm keen on the clean engine bay and less shit going back through the carby. Motor has been rebuilt and will hopefully have very minimal blowby. Not sure if the breather filters just clog with oil or not. Share this post Link to post Share on other sites
deankxf 20,292 Posted April 23, 2016 this is how i did mine..was ages ago, probably did it that way because it was easiest at the timeif i was doing it again i'd tap and put a bolt in the port i plugged.. could mount an ignition lead stay on it. Share this post Link to post Share on other sites
