Gerry Ahern 366 Posted March 14, 2015 Anyone have any tips on unclipping speedo clip? Have removed the 4 screws, pulled speedo/tacho frward but can't get at it. Thanks Share this post Link to post Share on other sites
adrianphu123 73 Posted March 15, 2015 Have you undone the wiring plug on the bottom left? i think theres a small button/area in the middle of the plug you have to press to remove Share this post Link to post Share on other sites
Gerry Ahern 366 Posted March 15, 2015 No Adrian. The speedo cable is holding the instruments in. Do you think the wiring plug is holding it in rather than the speedo cable? Share this post Link to post Share on other sites
deankxf 20,307 Posted March 15, 2015 what car is it? Share this post Link to post Share on other sites
VDO 124 Posted March 15, 2015 Just push down on the white plastic outer clip and then pull. It should come right out unless the cable into the speedo head is gummed up, which means you'll have to wriggle and pull a bit harder. 1 Thom reacted to this Share this post Link to post Share on other sites
