JGP 14 Posted December 18, 2014 Howdy all, as title suggests. To remove is (if I remember from 15yrs ago) bolts along top, behind the front wheel, remove indicator and there is another bolt there? Was going to clean it up, use POR metal ready and then spray matt black the inside the of the guard. Sound like a good idea? Any suggestions welcome. Cheers Share this post Link to post Share on other sites
Mr Polson 10,214 Posted December 18, 2014 Also bolt in under the corner of the windscreen, open the door and you'll see it. Share this post Link to post Share on other sites
wagoon 2,429 Posted December 19, 2014 2 bolts hold it to the bumper as well Share this post Link to post Share on other sites
bear351c 10,276 Posted December 20, 2014 Morris Minor ?? Humber Super Snipe ?? 1 wagoon reacted to this Share this post Link to post Share on other sites
hendrixhc 10,922 Posted December 21, 2014 Dont forget the mud, shit, rust and seam sealer as well. Share this post Link to post Share on other sites
Nath 1,975 Posted December 21, 2014 Having the same issue... can't seem to get it off. The back part (near the windscreen) is loose, got all those bolts, but there's something at the front holding it in. Got the one behind the indicator, and the screw holding it in with the bumper, but something's still stuck... Share this post Link to post Share on other sites
wagoon 2,429 Posted December 21, 2014 There 2 bolts that hold the bumper to the guard Share this post Link to post Share on other sites
JGP 14 Posted December 22, 2014 When screwing guard back on should I use seam sealer, along the top bolts? Share this post Link to post Share on other sites
JGP 14 Posted December 22, 2014 dammit, cant get the middle top screw off, next to the rubber bonnet stopper. the back of it has a thin metal washer nut (im sure there's a name for it). screw just keeps spinning and cant get anything underneath to hold it. any suggestions? also how would you go about putting it back together again? cheers Share this post Link to post Share on other sites
JGP 14 Posted December 22, 2014 scratch previous post! got it sorted, must of been heatstroked! are these the correct bolt kits?: http://www.ebay.com.au/itm/FORD-REPRO-ZINC-PANEL-BOLTS-AND-NUTS-TO-SUIT-XD-XE-XF-MODELS-/131001854096?pt=AU_Car_Parts_Accessories&hash=item1e8051a890 Share this post Link to post Share on other sites
JGP 14 Posted December 22, 2014 pics: http://i326.photobucket.com/albums/k421/jgpatricks265/20141222_142507_zps17a3c328.jpg http://i326.photobucket.com/albums/k421/jgpatricks265/20141222_142501_zps6abdac8c.jpg Share this post Link to post Share on other sites
Mr Polson 10,214 Posted December 22, 2014 That should show the pics up in the thread... Share this post Link to post Share on other sites
bear351c 10,276 Posted December 23, 2014 scratch previous post! got it sorted, must of been heatstroked! are these the correct bolt kits?: http://www.ebay.com.au/itm/FORD-REPRO-ZINC-PANEL-BOLTS-AND-NUTS-TO-SUIT-XD-XE-XF-MODELS-/131001854096?pt=AU_Car_Parts_Accessories&hash=item1e8051a890 Yep, that's them....... Aaah........, it's an XD Share this post Link to post Share on other sites
