NZXD
XD Falcon Ignition barrel wiring.
Recommended Posts
Hey guys, I'm slightly concerned at the wiring in my XD. I thought all was sorted until I went to plug the 6 wire loom from the ignition barrel to the small loom that goes into the engine bay.
The colours do no match when plugged in and there's a wire been cut.
Can anybody post a picture of the two plugs together showing the wires corresponding?
Cheers
Share this post
Link to post
Share on other sites
Today's job was to tidy up the wiring under the dash, turns out that the power coming into the cabin (two yellow, two black, purple/white and a white) do not plug into the ignition barrel as I found the right plug up under/ behind the fuse panel.
Today's drama is that I have nothing to plug the brake pedal plug or the ignition barrel into.
I have pulled most of the dash out again and I'm lost as to where it has gone? I can only think aliens have taken it.
Share this post
Link to post
Can anyone provide some info on the factory resistor that leads to the coil?
I have a mallory comp s/s 42 series dizzy which (how I read it) requires a resistor in the line to the coil or failure of the ignition module will ensure.
I have a msd blaster 2 cool.
My XD was originally a 6, so it should have a resistor in the loom.
Anybody see any issues?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
