dusty_ben
Ba everything into Xf
Hey guys putting a barra into my Xf. Going to run a ba steering wheel so I think I'll try a ba steering column. I'll run the ba stalks n key barrel. Wondering if I can run the lock and unlock buttons on the key. Any ideas on how I could do this? Would I be able to use a aftermarket centre locking kit n program the factory fob? Or could I use the ba bcm n run the power windows also from it. <br />Cheers for the help. New to electrics n jumping in the deep end with this build<br />Ben
Heya Ben =) , you will have the triggers for the central locking from the ECU, all you need is motors in the doors for them to trigger the locks and to run the central locking wiring to the doors.
Basically, you need the whole harness from the BA everything from the back of the cab , forward.
Hope that helps. Jack.
