Fox
Removing xe front guards?
Recommended Posts
Hi guys
As the title says I was wondering if you could give
Me some step by step info on how to do it.
Thanks in advance.
Share this post
Link to post
Share on other sites
remove headlights and blinkers as there is 3 bolts each side joining front guard to bumper each side
there are two bolts at the bottom of each guard ,and the rest across the top easy enough to be seen
also remove both front windscreen moulds youl find one bolt on each side  of the screen ,there all 10 mil
Share this post
Link to post
The guards I just took off my xe wagon had the rusted bolts from guard to bumper as Rev said. Bolt would just spin when I tried undoing it so I hit the bolt with a lot of crc held the bolt above the nut with vice grips and then turned the nut. Then applied more crc and repeat. I think it took about 3 hours to get 4 bolts out. Could also apply a small amount of heat to just the nut then spray crc/wd40 if the nut wont come loose.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
