Fox 1 Posted June 26, 2014 Hi guys As the title says I was wondering if you could give Me some step by step info on how to do it. Thanks in advance. Share this post Link to post Share on other sites
revhead 1,392 Posted June 26, 2014 remove headlights and blinkers as there is 3 bolts each side joining front guard to bumper each side there are two bolts at the bottom of each guard ,and the rest across the top easy enough to be seen also remove both front windscreen moulds youl find one bolt on each side of the screen ,there all 10 mil 1 steve mcqueen reacted to this Share this post Link to post Share on other sites
Fox 1 Posted June 26, 2014 Cheers thanks revhead I'll give it a go. Share this post Link to post Share on other sites
revhead 1,392 Posted June 26, 2014 go to it lad ,I bet ya the bolts on the front bar to guard snap off! lol as they rust like shit, Share this post Link to post Share on other sites
wagoon 2,429 Posted June 27, 2014 The guards I just took off my xe wagon had the rusted bolts from guard to bumper as Rev said. Bolt would just spin when I tried undoing it so I hit the bolt with a lot of crc held the bolt above the nut with vice grips and then turned the nut. Then applied more crc and repeat. I think it took about 3 hours to get 4 bolts out. Could also apply a small amount of heat to just the nut then spray crc/wd40 if the nut wont come loose. 1 revhead reacted to this Share this post Link to post Share on other sites
