Sign in to follow this
rocklord
Maximum Clutch Diameter - 4 Speed Bellhousing
My Crossflow was set up for a C4, buy I want to switch to a T-5.
I have a 4 speed bellhousing, and can get an adapter for the T-5 along with a 157-tooth 302 flywheel.
I don't know what size clutch I can use with the bellhousing I have, 10-inch or 10.5.
Does anyone know what the maximum size clutch I can run with this bellhousing?
Cheers
They can fit 10.5" size if the flywheel is drilled for that pattern. 11" is for 164-tooth only. Make sure when ordering the Windsor flywheel you ask for zero balance. 28 and 50 oz imbalanced flywheels are for V8s only, zero is for (modified) internally balanced V8s and 6 cyls. Your gearbox adaptor would require use of the long V8 input shaft to allow for the extra distance from the flywheel created by the spacer. This in turn would place the box and thus the shifter further back and maybe not line up with the hole in the tunnel. Also your tailshaft will need to be shorter. If you've already thought of all this then disregard.
Thanks for the reply gerg, just what I needed to know.
I have a chance to purchase a Hayes billet flywheel and Centerforce 10.5-inch clutch kit from a guy with a 302 Mustang for a good price.
The flywheel is zero balance.
Cheers
