Mr Polson 10,214 Posted March 14, 2014 Hey guys, wanting to wire up factory style driving/fog lights like below. (I think they're driving because they're not yellow). Now I got the factory relay (and wiring) out of the Ghia wagon. Its a 4 pin relay, with five wires. 2x Green/white (from same pin) - For each light? 1x Green/white (has clip on it) - Wire from switch for lights? 1x Yellow (has inline fuse) - for positive from battery 1x black - Negative So how do I wire it in to get it working? Obviously the wires to the battery and each individual light are self explanatory. Guessing just put the earth somewhere to earth. What about the wire for the switch? Will my (base model) GL have the plug/loom for the lights? Or will I have to run my own wires to the switch in the dash? Share this post Link to post Share on other sites
xd4.1efisc 34 Posted March 14, 2014 The wire (green/white)from the switch should be there near the headlight relays, and the switch plug should be near the fuse box as well. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted March 16, 2014 Yep, everything was there to plug into. Got them all working, only thing is I can't get the dash light for it to work? Tried known good globe in there for it and it still doesn't illuminate. Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted March 16, 2014 Pull the cluster out, take it apart and clean the contact. 1 Mr Polson reacted to this Share this post Link to post Share on other sites
