Sign in to follow this
NZXD
Desktop dynos
Recommended Posts
I found this 302 Cleveland forsale where the owner uses a desktop dyno to estimate the hp.
I found the same programme on comp cams website, I'm sure its not that accurate.
Here is the advert for the clevo
https://touch.trademe.co.nz/listing/view/676702965
I would be very cautious of the hp level as quoted, I highly doubt it would produce the numbers.
Share this post
Link to post
Share on other sites
i got 382hp 382ftlbs
using 10:1 comp.
in all honesty, its usually within 5-10% from what i've seen. because it estimates power without running anything but the engine (that means no water pump, no accessories etc) and perfect conditions.
Share this post
Link to post
I put my 302 Windsor specs into the same calculator, I found a similar cam, I have alloy heads and 10:1 comp, said 420hp, I'm like nah that's not right.
Share this post
Link to post
I'd say no way near that hose power its cam is 268adv, 218@0.050", 494" lift, I'd say 280-290hp
My 302 Clevo has a 280adv, 214@0.050", 510" lift, and would be lucky for 320hp once I get the hi rise manifold on.
which I might stick on an engine dyno while I'm on holidays.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
