XF EDDIE 207 Posted January 21 My ute came with the spare, jack and a wing nut but I cant figure out where it bolts to. There is no hole in the center for the nut and I cant find a photo on the web. A photo would be much appreciated Share this post Link to post Share on other sites
SPArKy_Dave 9,344 Posted January 21 It threads onto a removable threaded bracket, that wedges against the tyre. The wing nut threads onto the bracket in reverse, and is then tightened down against an opposing bracket, welded inside the wheel carrier - on the RHS. XR-XG utes/vans all use the same bracket/nut. 2 deankxf and XF EDDIE reacted to this Share this post Link to post Share on other sites
XF EDDIE 207 Posted January 21 So the wheel dosent sit flat on the floor? Share this post Link to post Share on other sites
XF EDDIE 207 Posted January 21 I feel like this should be simple but its got me stumped This is the correct bracket right? 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 9,344 Posted January 21 44 minutes ago, XF EDDIE said: I feel like this should be simple but its got me stumped This is the correct bracket right? That's it yes! The loose threaded bracket, sits against the tyre, with the threaded end in the slotted hole of that welded bracket. The wingnut winds on the thread upside down, so it tightens backwards against the outside of that welded bracket, thus pushing the loose threaded bracket, against the tyre. Share this post Link to post Share on other sites
deankxf 21,128 Posted January 22 13 hours ago, SPArKy_Dave said: That's it yes! The loose threaded bracket, sits against the tyre, with the threaded end in the slotted hole of that welded bracket. The wingnut winds on the thread upside down, so it tightens backwards against the outside of that welded bracket, thus pushing the loose threaded bracket, against the tyre. i used My awesome paint skills and made this.. 1 1 SPArKy_Dave and XF EDDIE reacted to this Share this post Link to post Share on other sites
XF EDDIE 207 Posted January 22 29 minutes ago, deankxf said: i used My awesome paint skills and made this.. Thanks for that Ill give it a go when I get back from work 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 21,128 Posted January 22 1 minute ago, XF EDDIE said: Thanks for that Ill give it a go when I get back from work the bracket thing could be upside down in the pic, if you can, take a photo when you try it and we might be able to have one on hand for future (its' the first time i've seen one.. usually there's a gas tank in my X series ute spare wheel space) Share this post Link to post Share on other sites
XF EDDIE 207 Posted January 22 12 minutes ago, deankxf said: the bracket thing could be upside down in the pic, if you can, take a photo when you try it and we might be able to have one on hand for future (its' the first time i've seen one.. usually there's a gas tank in my X series ute spare wheel space) Yeah man will do, The only other xf ute ive seen also just had a gas tank so it had me fucked 1 deankxf reacted to this Share this post Link to post Share on other sites
XF EDDIE 207 Posted January 22 Hey presto Make sure to save it as discord links like to go dead! 1 1 deankxf and SPArKy_Dave reacted to this Share this post Link to post Share on other sites
deankxf 21,128 Posted January 22 2 hours ago, XF EDDIE said: Hey presto Make sure to save it as discord links like to go dead! @SPArKy_Dave keeps the photos of everything.. i'll attempt to find it again and probably won't be able to even next week. but here it is uploaded to the forum. 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
