AAAC 60 Posted April 16 My XF 4.1 unleaded ute was running very poorly. I refreshed the carburettor and it is vastly improved, running sweet except when quickly opening the throttle in second and third in the three-on-the tree manual. I suspect that there is a vacuum leak at the site of the hastily removed and blanked off EGR valve, which I will get back to. The carburettor looked like a mix of XD and XE parts. There was a wound spring on the throttle shaft, which is still there, and another about 5cm long attached to the throttle lever at one end with the other end looped around the nearby EGR bolt, which can't have been right. I am running the car without it and it has been fine. Is there meant to be another spring and what are the attachment points? Share this post Link to post Share on other sites
deankxf 20,315 Posted April 16 1 hour ago, AAAC said: Is there meant to be another spring and what are the attachment points? i haven't got any photos handy at the moment, but this thread has a lot of info in it if you have time to check it out 1 AAAC reacted to this Share this post Link to post Share on other sites
AAAC 60 Posted April 16 Thanks deankxf. On the third photo posted by zkfairlane, there is a link running vertically down into the depths of the engine bay attached to the throttle lever. Mine had the spring running from there to the EGR valve and no lever. I cannot find a reference to the lever in my XF workshop manual. Share this post Link to post Share on other sites
