the miracle stick mechanic 46 Posted October 4, 2022 Latch removal: 1.Remove door trim. 2.Disconnect Inner door handle rod at handle end only by removing M6 bolt. 3.Pull Outside door lock rod from plastic lever on the back of the key lock. 4.Unclip Outside door handle rod at handle end only. 5.Remove M6 bolt and remove lower section of the rear window runner by sliding it downwards . 6.Remove three M6 bolts fastening latch/lock mechanism to the door . 7.Before removing latch from inside the door remove only the inside door button lock rod at the latch end. 8.Leaving the other 3 operating rods attached remove the latch through the rear upper hole in the door frame. Soak the latch in oil overnight and do not remove the rods unless necessary . Reverse for installation . Share this post Link to post Share on other sites
