bearmunger 1 Posted May 9, 2020 Hi easy one will EL Auto fit XG if so any changing of looms or elecs cheers Share this post Link to post Share on other sites
deankxf 21,128 Posted May 9, 2020 3 hours ago, bearmunger said: Hi easy one will EL Auto fit XG if so any changing of looms or elecs cheers this response is from a mate of mine Bolt straight in, plug straight in, and away you go, zero mods, direct fit, keep the bellhousing and torque converter with the EL box, the XG converter will probably work fine though actually, not in XR6 form(all T bar i'd bet), but if anyone else needs to know later, make sure the bell housing can mount a column shift on before fitting it all up if your car is column shift as easy as fitting another XG auto, except the EL one has no dipstick, so you have to follow the EL filling instructions 1 bearmunger reacted to this Share this post Link to post Share on other sites
bearmunger 1 Posted May 9, 2020 Thanks for your help I can chill out now 1 deankxf reacted to this Share this post Link to post Share on other sites
