Jackofharts 0 Posted February 26, 2020 I have a xa factory six was wanting to convert it to a 351 I’ve recently bought a xf Ute was just wondering if the disc brake diff from the xf will fit the xa. Also the xf has a c6 trans bolted to the 351 just curious what tail shaft I will need thanks Share this post Link to post Share on other sites
gerg 10,875 Posted February 26, 2020 I have a xa factory six was wanting to convert it to a 351 I’ve recently bought a xf Ute was just wondering if the disc brake diff from the xf will fit the xa. Also the xf has a c6 trans bolted to the 351 just curious what tail shaft I will need thanks I fitted an XG diff to my XE. They are pretty much unchanged up till then. You can fit the later flat flange yoke to earlier diffs if you want to run a later driveshaft.Not sure about the C6 tailshaft. Not a common box in Aus.Sent from my CPH1903 using Tapatalk Share this post Link to post Share on other sites
Jackofharts 0 Posted February 26, 2020 Thanks for that if the diffs swap straight over that will make it a lot easier Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
