car10001 52 Posted January 22, 2019 Hi just a couple questions 1. Could you make a ed climate control panel work on el ghia v8 wiring and what’s best way to make it work. Swapping plugs would be easy if you follow diagram. Was thinking go through a ed and el diagram and work out what needs changing. 2. When using a el v8 ecu on a ed trip computer are you able to cut the pwm wire at trip computer plug and run new wire then splice into pwm injector pulse on the v8 ecu like you can with the 6 cyl. thanks Share this post Link to post Share on other sites
