Panko 2,481 Posted April 9 Going back a bit, these are a couple of photos rolling into Small Ford Sunday. taken no more than 30 seconds apart, on two different cameras, but makes the colour look completely different. this colour still amazes, but also annoys me with how both good and bad it can look depending on the light its in the joys of metallic paint i guess.  *the second pic is more true to the actual colour**    I finally got the front bumpers back, and they came up fantastic. worth the wait.   Now onto some mechanical gremlins. I had been having an issue with the cooling system. not over heating, but in fact running too cold. not getting warm enough to actually open the thermostat, which was a standard 89 degree thermostat. I figured it was because the alloy radiator was so efficient at cooling that yeah meant that I couldn't get her up to temp, and had no heater.  This whole time I had been running just water in the cooling system, not coolant, to try flush the system out as best I can. I figured with this lack of heating issue, id pull the thermostat out and then put some coolant in.   This is what came out. its a piece of gasket goo stuck in the thermostat. notice also the colour. that thermostat was brand new with this engine. so it has gone a very rusty brown colour thanks to the water. Pushing on the diaphragm by hand, the thermostat felt a little sticky. didnt want to move smoothly to open or close.  So I ended replacing it with an 82 degree thermostat. not to make it run cooler, but so the thermostat would open earlier and start circulating coolant earlier. with that, and coolant in the system, it has made a difference. it gets up to the correct 88 degrees running temp now, rather than running too cold.  Good Friday, the RSOCV had their annual Good Friday cruise. Over 30 cars got involved, and we went out to Warburton, up Mt Donna Buang (some of us more spiritedly than others) then back down and to Yarra Glen Hotel for lunch. Having driven the Escort up there previously with the 1300, flat out, and now with the 1660, also flat out, it was a much faster drive up there. I had a mate of mine in his Mini come along, who was behind me on the way up. Although I am not too concerned, he did tell me that it was blowing a bit of blue smoke between gear changes. granted I was pushing it, its the hardest it had been driven, and it was mighty cold up there. but it did it well. I adjusted the suspension up a bit to be stiffer, and boy does it turn well.  On the way home, my buddy in the mini, and me couldnt resist but to see how they compared. its the first time the mini and escort had been out together. the Mini is a 1999 Rover, with a single point injected 1275cc, from Japan. Its since had a Cooper performance kit fitted, which includes a ported head with roller rockers, headers, exhaust, bigger injector, and a few other go fast parts. The Mini weighs 100kg less than the Escort, at 740kg, and with the Cooper engine package produces about 65kw. The Escort, a stock 1600 produces 60-65kw. Mine is a 1660, with a cam, weber, etc etc. It was a good comparison, the Mini nudged in front basically because i was slow getting into 2nd gear, otherwise equally matched. So for such a small engine in the Mini, it goes really well. its pretty quick little thing.  I had to do a weekend run over to work HQ in Footscray, so jumped in the Escort to save the diesel in my daily. it really is such a great improvement over what it used to be in pretty much every aspect. able to sit on the highway comfortably, plenty of grunt to pull away, it just gets very warm in the cabin very easily, which was always the case.  1 3 Loonar, deankxf, JackFrost and 1 other reacted to this Share this post Link to post Share on other sites
