Free.51 2,717 Posted December 2, 2015 Hi guys i wont to know if i can use ba-fg rear bump stops on my FD? Ive tried to get hold of x series ones but no luck unless i buy the shocks too. I saw these on eBay & thought i wonder if theyll work what do u guys think? Share this post Link to post Share on other sites
adrianphu123 73 Posted December 3, 2015 If its the dimensions you want, i dont see why not. It has no other function other than to physically be there Share this post Link to post Share on other sites
xr6tjet 98 Posted December 3, 2015 They are significantly bigger than regular bump stops on the old x series, and these only have one sided drilled to press and attach the bump stop over a metal knob on the BA. I'm pretty sure you can still get regular ones from nolthane to suit x series? Share this post Link to post Share on other sites
Nath 1,975 Posted December 3, 2015 Why on earth would you want nolathane bump stops? Share this post Link to post Share on other sites
Free.51 2,717 Posted December 3, 2015 Just looked at thé nolathane website, it has every bush except rear shock bump stop .forme x series Share this post Link to post Share on other sites
SPArKy_Dave 8,871 Posted December 3, 2015 Pedders - Rear Bump Stop / Kit 4360 Bump Stop-1pk http://www.pedders.com.au/catalogue/ford/ltd/1982-1988-fd-fe Share this post Link to post Share on other sites
wagoon 2,429 Posted December 3, 2015 Why on earth would you want nolathane bump stops? Superpro make a bump stop for the front that is shorter than standard so you don't have to cut them and make you car illegal. Is the rear bump stop your talking about the snubber bush above the front of the diff housing? 1 Nath reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted December 3, 2015 Pedders - Rear Bump Stop / Kit 4360 Bump Stop-1pk http://www.pedders.com.au/catalogue/ford/ltd/1982-1988-fd-fe WOW if you search that part number in goggle it lists the same part number for stuff like BMW 5 series 77-81 models, Mitsubishi mirage 96-2000 models and many more. So if you didn't want nolathane maybe you could go to a wreckers and see if the OEM parts on the cars listed are the same as the falcons Share this post Link to post Share on other sites
Grimmy 312 Posted December 3, 2015 Is this front or rear for the X series ? I use ba front bump stops in the front of mine , I assume they'ed work in the rear of an xe/f aswell Rear ba bumpstops are huge , fronts are smaller and look more like rear X series Share this post Link to post Share on other sites
Free.51 2,717 Posted December 3, 2015 Pedders - Rear Bump Stop / Kit 4360 Bump Stop-1pk http://www.pedders.com.au/catalogue/ford/ltd/1982-1988-fd-fe Thanks Dave i'll give them a buzz. Share this post Link to post Share on other sites
