BGDAV 1,874 Posted December 3, 2014 has anyone run a hydraulic master cylinder which is larger then that standard PBR unit ? if so where did you get it ? Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted December 4, 2014 go through the PBR catalouge, there will be something there for sure. what size master cyl are you looking for? Share this post Link to post Share on other sites
BGDAV 1,874 Posted December 4, 2014 had a call around etc pbr only makes one size due to the weird offset i need 3/4, ive run the standard before but i think would be better running the larger size, best way from my reading is to make an adaptor to run a straight up and down mount which shouldnt be to hard to knock up Share this post Link to post Share on other sites
Olive Xm 34 Posted December 4, 2014 When I was looking at this, I was going to get my standard one bored and sleeved to suit 3/4. Then use the piston from a 3/4 straight up one. The guy at the brake place said thats how he had done it before. Share this post Link to post Share on other sites
BGDAV 1,874 Posted December 4, 2014 thanks for that, i might take them both down and see if they can do that, would be easyer Share this post Link to post Share on other sites
