XF001 93 Posted May 23, 2014 Has anyone put 2 bucket seats in the back of an x series falcon instead of the full width seat? Share this post Link to post Share on other sites
Gaz 1,085 Posted May 23, 2014 Been done before but needs engineering. Share this post Link to post Share on other sites
revhead 1,392 Posted May 23, 2014 it can be done if done right its easy to get engineered , all you do is remove the seat runners ,make a carboard templete of the seat base holes ,to mark the rear floor out with ,remember on the right rear side you have the exhuast heat sheild to work around, ,,,on xf front seats they have black nylon spacers you put one under the front two bolt on each front seats to give leg support what youl need it 4x 50x50 10 mil thick plates case hardened or black bolts ,to bolt seat down with ,per seat ,take your tie dont rush and itl look awesome Share this post Link to post Share on other sites
