Justo 1 Posted March 21, 2014 hey everyone, ok so after putting a xe wiring loom and dash into my xf i came across a lot of problems with my lights now there all fixed except for one thing my HIGH BEAMSSS! they don't work flash does mbut no high beam so i bought a new switch replaced relays and fuses and then i was like fuck it i'll put the old xe switch on and see if that works and now everything works fine BUT i can't use my switch to pass rego its broken little metal pin and plastic casing is broken and just falls down so its always turning right but any way i want to put my xf one in how? are the wires different some how between them they all look the same? and whats this random green and white wire go to that is from the pink and yellow wire on the headlight plug( they weren't connected at all even when the xe switch fixed the high beam issue? please help ???? Share this post Link to post Share on other sites
Justo 1 Posted March 21, 2014 fixed it just swapped the red black wire to the red yellow wire and then the red yellow wire to the red black wire and all good now no parkers ? wtf?? Share this post Link to post Share on other sites
