SPArKy_Dave 9,344 Posted May 27, 2024 12 hours ago, Tazvan said: The Weber I removed from the XE 3.3 motor has throttle plates that open up fully...?? and doesn't have a PTC heater basket under it...? I think the PTC heater, is an XF only thing? Share this post Link to post Share on other sites
Tazvan 123 Posted May 27, 2024 38 minutes ago, Thom said: When I was 19 I had an xf wagon I got from the original owner, it had 60,000ks on it it was a 4.1 and was the slowest car I had ever driven (I even pulled the plugs and measured the stroke to make sure it was a 250 and not a 200) turns out it had a webber from a 3.3 on it previous owner swore black and blue the carb was original to the car, I put a webber off a 250 on it and it made a huge difference Not sure if that should make a difference as I think they are virtually identical...mine goes quite well really... Share this post Link to post Share on other sites
Tazvan 123 Posted May 27, 2024 14 minutes ago, SPArKy_Dave said: I think the PTC heater, is an XF only thing? I read somewhere only 3.3's had the PTC, but hey it seems there are exceptions sometimes, and anything may have been done in warranty scenarios... 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
Thom 6,710 Posted May 27, 2024 Not sure if that should make a difference as I think they are virtually identical...mine goes quite well really...It may have had other problems I wasn't as good with carbs back then, as much as I thought I was at the time, but you can learn a little bit in 15 years, I do remember it making a huge difference to that car at the time, it made as much of an improvement as putting an efi cam in it and swapping the auto for a t5 1 Tazvan reacted to this Share this post Link to post Share on other sites
Tazvan 123 Posted May 27, 2024 What ever works is fine with me Share this post Link to post Share on other sites
