Rendetoyeti
BW40 band adjustment
Hey guys.
I have an old beat-up xe with a BW40 that drives fine in reverse but barely moves in drive. I have removed the box and want to know how to adjust the bands. All I'm looking for is enough to be able to drive it onto a trailer. Any help would be much appreciated.
There's only two band adjustments on them.
Front band, accessed by removing the pan, and rear band at the back R/H side, up top,
also the kickdown cable, which affects fluid pressure.
The Rear (First/Reverse) Band is easy -
Loosen locknut, tighten bolt to 14Nm, back off bolt 3/4 of a turn, then re-tighten locknut.
Front (Second/Third) Band is a bit harder -
Remove oil pan, place a 1/4 inch spacer between band servo piston and the end of the adjusting bolt.
Loosen lock nut, tighten adjuster screw to 1.1Nm, then re-tighten locknut
Parts list -
https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/BW35/
Also see this thread -
