Sign in to follow this
adrianphu123
Removing rear door latch mechanism
Recommended Posts
Hey guys,
Need a bit of assistance with removing the latch mechanism out of the rear doors. I have all the rods disconnected except the latch to door lock bellcrank rod. Any ideas? i dont have enough room to twist the mechanism to get the rod out of either end.
thanks.
adrian
Share this post
Link to post
Share on other sites
To get the rear door handle disconnected, you have to undo both screws and remove the handle with the rod still attached. Once out then you have enough room to get the rod out. It's tricky the first time you go one but they do get easier.
Share this post
Link to post
Oops, just read "latch mechanism"... Yep they are a bastard. From memory mine consisted of a lot of swearing and some bleeding knuckles.
Again, from memory, you had to rotate the mechanism inside the door cavity to get the right angle to pull the rod off. Hopefully someone will chime in with some pics.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
