genemoore 1 Posted December 8, 2021 I have a 250 crossflow with Yella Terra Roller Rockers and just discovered after taking the tappet cover off that the push rods are loose is this a common thing for the Yella Terra Roller Rockers to become loose Share this post Link to post Share on other sites
gerg 10,871 Posted December 8, 2021 I have a 250 crossflow with Yella Terra Roller Rockers and just discovered after taking the tappet cover off that the push rods are loose is this a common thing for the Yella Terra Roller Rockers to become looseIs it a case of the rockers coming loose, or your lifters collapsing/wearing out? Are your lifters bolt-on pedestal or adjustable stud-mounted? Are the rockers also adjustable at the pushrod end?Sent from my CPH1920 using Tapatalk Share this post Link to post Share on other sites
genemoore 1 Posted December 8, 2021 Ypu mean are the rockers bolt on or pedestal mounted? Share this post Link to post Share on other sites
genemoore 1 Posted December 8, 2021 You mean are the rockers bolt on or pedestal mounted? Sorry it.wont let me.upload.a.pic grrrr I'm pretty sure they are pedestal mounted and adjustable at the pushrods, Everything on the roller rockers are tight no loose fasteners but I'm able to lift the roller rockers off the valve springs a bit . Share this post Link to post Share on other sites
genemoore 1 Posted December 8, 2021 If can help with some advice my email is- gktm99@gmail.com Share this post Link to post Share on other sites
gerg 10,871 Posted December 8, 2021 If can help with some advice my email is- gktm99@gmail.com You can post pics either through Photobucket or sign up to Tapatalk and access the forum through that, and it also enables pics to be sent along with the message. That's the one I use.Sent from my CPH1920 using Tapatalk Share this post Link to post Share on other sites
genemoore 1 Posted December 8, 2021 Mate your talking a whole new language I wouldn't know where to start, this is the first forum I've joined Share this post Link to post Share on other sites
gerg 10,871 Posted December 8, 2021 Tapatalk is a forum hosting app on your phone or (maybe) computer... Anyway, the pic you emailed:Those are adjustable at the pushrod end, meaning they might not have been adjusted right but if this engine hasn't been run yet, the lifters will be empty of oil so the free play you are witnessing is the light pressure that the lifter preload spring provides.If there is no light pressure and the rocker is freely flopping back and forth, the initial adjustment procedure should be followed.I would do it by backing off the locknut on each one, rotate the engine around to TDC compression on each cylinder you're doing and wind the Allen key adjuster in till it just contacts the pushrod. Then go 3/4 of a turn in to achieve lifter preload. Lock the nut at that setting and move to the next. Repeat process in firing order 1-5-3-6-2-4 till all are done. Sent from my CPH1920 using Tapatalk 1 bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted December 8, 2021 Yep, what he said. ^ ^ ^ Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted December 8, 2021 note that when using roller rockers on a crossflow ,the cup in the rocker that holds the pushrod sometimes is set deeper than stock ,i found this out on my crossflow after having it milled it actually needed longer than stock length which i couldnt work out until the machine shop told me ,will depend on brand of rocker. 2 bear351c and gerg reacted to this Share this post Link to post Share on other sites
genemoore 1 Posted December 10, 2021 On 12/9/2021 at 1:00 AM, gerg said: Tapatalk is a forum hosting app on your phone or (maybe) computer... Anyway, the pic you emailed: Those are adjustable at the pushrod end, meaning they might not have been adjusted right but if this engine hasn't been run yet, the lifters will be empty of oil so the free play you are witnessing is the light pressure that the lifter preload spring provides. If there is no light pressure and the rocker is freely flopping back and forth, the initial adjustment procedure should be followed. I would do it by backing off the locknut on each one, rotate the engine around to TDC compression on each cylinder you're doing and wind the Allen key adjuster in till it just contacts the pushrod. Then go 3/4 of a turn in to achieve lifter preload. Lock the nut at that setting and move to the next. Repeat process in firing order 1-5-3-6-2-4 till all are done. Sent from my CPH1920 using Tapatalk Ah yes I totally forgot about the hydro lifters so of course I can move the rockers.and pushrods.seem loose The motor has been well.run in maybe 10000 kms ,its 20.years old and I never got to finish it til now I gave the inside a.major clean and.oil but.it hasn't been started back up again.amd I'm in that process but have to assemble all gaskets and bolt.ons again.,.so would i stil follow that procedure to recommended? 1 gerg reacted to this Share this post Link to post Share on other sites
genemoore 1 Posted December 10, 2021 On 12/9/2021 at 11:30 AM, CHESTNUTXE said: note that when using roller rockers on a crossflow ,the cup in the rocker that holds the pushrod sometimes is set deeper than stock ,i found this out on my crossflow after having it milled it actually needed longer than stock length which i couldnt work out until the machine shop told me ,will depend on brand of rocker. Yes I was informed about.this when I ordered the one piece chrome molly pushrods Share this post Link to post Share on other sites
