Jon Kirkwood 0 Posted September 24, 2021 Hi. I am wondering why the XA B C diffs have the 10 mm spacer on the axle retainer plate snd the bearing Thanks for any answers. Share this post Link to post Share on other sites
deankxf 20,287 Posted September 24, 2021 2 hours ago, Jon Kirkwood said: Hi. I am wondering why the XA B C diffs have the 10 mm spacer on the axle retainer plate snd the bearing Thanks for any answers. @gerg is this the issue you had with your diff? disc/drum difference Share this post Link to post Share on other sites
gerg 10,871 Posted September 24, 2021 [mention=244]gerg[/mention] is this the issue you had with your diff? disc/drum differenceI have a BW78, this is regarding a 9-inch, which I have never owned or worked on.Sent from my CPH1920 using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted September 24, 2021 I would say, it's probably for the old style "wide" bearings. Dont think many people use them anymore, the side loads when cornering wore them out prematurely, I believe. Not 100% sure, The 9" s that I have used, shortened, fitted all had the thinner bearings, and standard axle plates. 1 gerg reacted to this Share this post Link to post Share on other sites
Jon Kirkwood 0 Posted September 30, 2021 It is a drum brake rear. It has the normal narrow bearing the spacers appear to do nothing does not change diff length or brake offset. Share this post Link to post Share on other sites
bear351c 10,270 Posted October 2, 2021 Oh ok, not sure then. Maybe spacer plates as you said. XY is about an inch or so shorter than an XA, (I think?) Share this post Link to post Share on other sites
