Server maintenance Read more... ×
Todd
Brakes dragging after astra pump xy conversion
Recommended Posts
Brakes pedal dragging and can be really touchy and way too hard after
xy 351c astra pump conversion.booster passes basic test and loosened
master cylinder nuts to check rod adjustment and vacuum reading is terrible
at 14 at idle and only reaching 20 at 3000 rpm.
So I’m guessing my power steering pump stealing my vacuum has anyone come
across this before and any checks ideas too what’s causing this
Share this post
Link to post
Share on other sites
if you have an Astra power steering pump that i'm aware of they didn't have anything to do with brakes?
any chance you can take a pic of what you have (use tapatalk app with your phone to upload photos)
or google a photo, is it this one?
Share this post
Link to post
Yeah dean it that trw brand that you uploaded
Sent from my iPhone using Tapatalk
Share this post
Link to post
that's got nothing to do with the brakes then
it's not connected to the brakes at all.
when i've had brakes dragging it's been due to sticking callipers(pistons stuck due to irregular fluid changes/barn find sat for years issues)
or in the case of rear discs the stupid hand brake levers stick due to internal gunk.
have seen videos with issues in old hoses swelling internally and causing blockages that are hard to press and then drag (fluid doesn't release)
what is the condition of the rest of the brakes? hoses, pipes(rusty) brake fluid overdue for change etc
Share this post
Link to post
1 hour ago, Todd said:
Your where right dean right front calipher sticking
cool, pain in the neck still, but not uncommon especially with old brake parts.
probably just needs a calliper kit, depending on condition internally
Share this post
Link to post
Best to rebuild all brake components, you might find that when you do the callipers and go to bleed the brakes, you push the master cyl pistons into the gunk build up and brakes will still drag.
Share this post
Link to post
Agree 100%. You may end up pushing "junk" fluid back into the master cylinder etc, so flush the whole system out, bleed all the calipers/wheel cyls. Be prepared.!  the front caliper pistons may be rusty and need changing, could be expensive. But your life is worth it, Yes.??
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
