Todd 13 Posted July 31, 2021 Brakes pedal dragging and can be really touchy and way too hard after xy 351c astra pump conversion.booster passes basic test and loosened master cylinder nuts to check rod adjustment and vacuum reading is terrible at 14 at idle and only reaching 20 at 3000 rpm. So I’m guessing my power steering pump stealing my vacuum has anyone come across this before and any checks ideas too what’s causing this Share this post Link to post Share on other sites
deankxf 20,231 Posted July 31, 2021 2 hours ago, Todd said: Brakes pedal dragging and can be really touchy and way too hard after xy 351c astra pump conversion.booster passes basic test and loosened master cylinder nuts to check rod adjustment and vacuum reading is terrible at 14 at idle and only reaching 20 at 3000 rpm. So I’m guessing my power steering pump stealing my vacuum has anyone come across this before and any checks ideas too what’s causing this if you have an Astra power steering pump that i'm aware of they didn't have anything to do with brakes? any chance you can take a pic of what you have (use tapatalk app with your phone to upload photos) or google a photo, is it this one? Share this post Link to post Share on other sites
Todd 13 Posted August 1, 2021 if you have an Astra power steering pump that i'm aware of they didn't have anything to do with brakes? any chance you can take a pic of what you have (use tapatalk app with your phone to upload photos) or google a photo, is it this one?Yeah dean it that trw brand that you uploaded Sent from my iPhone using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,231 Posted August 1, 2021 19 minutes ago, Todd said: Yeah dean it that trw brand that you uploaded Sent from my iPhone using Tapatalk that's got nothing to do with the brakes then it's not connected to the brakes at all. when i've had brakes dragging it's been due to sticking callipers(pistons stuck due to irregular fluid changes/barn find sat for years issues) or in the case of rear discs the stupid hand brake levers stick due to internal gunk. have seen videos with issues in old hoses swelling internally and causing blockages that are hard to press and then drag (fluid doesn't release) what is the condition of the rest of the brakes? hoses, pipes(rusty) brake fluid overdue for change etc Share this post Link to post Share on other sites
Todd 13 Posted August 1, 2021 Thanks dean that will be my next set of checks ,front calipher hoses and rear hose (drum brakes) about 2 years old 1 deankxf reacted to this Share this post Link to post Share on other sites
Todd 13 Posted August 1, 2021 Your where right dean right front calipher sticking 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,231 Posted August 1, 2021 1 hour ago, Todd said: Your where right dean right front calipher sticking cool, pain in the neck still, but not uncommon especially with old brake parts. probably just needs a calliper kit, depending on condition internally Share this post Link to post Share on other sites
ESPSIX 143 Posted August 1, 2021 Best to rebuild all brake components, you might find that when you do the callipers and go to bleed the brakes, you push the master cyl pistons into the gunk build up and brakes will still drag. 1 deankxf reacted to this Share this post Link to post Share on other sites
bear351c 10,260 Posted August 3, 2021 On 8/2/2021 at 5:29 AM, ESPSIX said: Best to rebuild all brake components, you might find that when you do the callipers and go to bleed the brakes, you push the master cyl pistons into the gunk build up and brakes will still drag. Agree 100%. You may end up pushing "junk" fluid back into the master cylinder etc, so flush the whole system out, bleed all the calipers/wheel cyls. Be prepared.! the front caliper pistons may be rusty and need changing, could be expensive. But your life is worth it, Yes.?? Share this post Link to post Share on other sites
ESPSIX 143 Posted August 3, 2021 Before you bleed them, google, brake bleeding hack and watch the YouTube vid with the spray bottle pump. works awesome!! Share this post Link to post Share on other sites
