wemsoi 55 Posted July 7, 2021 So I have an xg falcon that is cranking but wont start. The fuel pump does prime however I believe it’s something electrical. I had the battery disconnected for about a day when I was doing some welding and rust repair. Then I also changed over the plug for the a new stereo and now its not getting any of the interior lights or smartlock flash on the dash. Everything else works tho headlight wipers indicators. What would the problem be. Was running beautifully 2 days ago. Share this post Link to post Share on other sites
deankxf 20,231 Posted July 7, 2021 check the interior light fuse/globe. (not 100% on globe, but the fuse is related i think) i had a feeling if that's not working it stops the smart lock working. Share this post Link to post Share on other sites
wemsoi 55 Posted July 7, 2021 30 minutes ago, deankdx said: check the interior light fuse/globe. (not 100% on globe, but the fuse is related i think) i had a feeling if that's not working it stops the smart lock working. Sorry for the ignorance but where is the fuse located. Share this post Link to post Share on other sites
deankxf 20,231 Posted July 7, 2021 57 minutes ago, wemsoi said: Sorry for the ignorance but where is the fuse located. not sure which fuse it is, in the fuse box. you need to undo 4 plastic screw things half a turn (cover that goes under the steering column, . need to push the handbrake in as it goes around the handbrake also. can see one of he plastic screws in this pic next to the white plug Share this post Link to post Share on other sites
Outback Jack 6,352 Posted July 8, 2021 Want to check a couple of fuses but yes the interior light fuse is one to check and Wiper fuse is also part of Smartlock.Does Smartlock light go out after you switch ignition ON or just stay blinking?Sent from my S21 using Tapatalk Share this post Link to post Share on other sites
wemsoi 55 Posted July 8, 2021 Ok so I checked and changed all the bad fuses. Car runs and is all sweet however every time I go to plug in the radio the interior light fuse blows. The wiring for the radio has been previously messed with by the owner before me. The stereo that was there before had no faceplate so a don’t really know if it worked. Share this post Link to post Share on other sites
wemsoi 55 Posted July 8, 2021 Im sure that the wiring for the stereo is wrong can does anyone know which wire does what. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted July 8, 2021 Hey Mate, ok.....Wiring .... This is from the deck.....Black- EarthOrange/Green- left speaker dash negative.Orange/ Black - left speaker dash positive.Grey/Green- right speaker dash negative.Grey/Black- right speaker dash positive.Brown to Parklamps. ?Blue/ White -12v fused off rad/CIG lighter.Green/Yellow- to Smartlock and instruments via interior lightSee pics for more details , match the wire numbers to the pins in the plug diagram below....Sent from my S21 using Tapatalk 1 wemsoi reacted to this Share this post Link to post Share on other sites
