Falcor 5 Posted July 5, 2021 Hi, I'm currently weighing up what I should do to my crossflow, Its got a cast iron head which is cracked and possibly causing low compression, the engine isn't idling very well, it also had overheating issues which a new radiator cap seemed to have fixed. I saw an old set of extractors out back that might fit, can I add them and a larger carby in place of cracked head? I'll take a photo of extractors so you can tell me if they'll fit for a start, I'm also open to new extractors. I gather there will be other parts and pieces I'll need... I'm also trying to do this without mods as I'd like to be able to keep it as original as possible for now. The engine was rebuilt 10,000km ago to stock specs. Is a 350 Holley suitable? Advice on a simple upgrade that might give more grunt and a better note... Can I upgrade my head to an alloy or something more modern? Thanks for your time, Wayne Share this post Link to post Share on other sites
Falcor 5 Posted July 5, 2021 Will these fit my crossflow? Sent from my SM-N975F using Tapatalk Share this post Link to post Share on other sites
deankxf 20,231 Posted July 5, 2021 in My opinion i wouldn't fit extractors to a stock engine, make no difference and just causes issues. dual bolt pattern means they should fit either alloy or iron head. providing they are from a falcon(assume so seeing there's a cat fitted) they'll fit the XC what's cracked? got a photo of what's cracked? Share this post Link to post Share on other sites
Falcor 5 Posted July 5, 2021 There's a crack in the cast exhaust manifoldSent from my SM-N975F using Tapatalk Share this post Link to post Share on other sites
deankxf 20,231 Posted July 5, 2021 if you just want it to sound better fit a glass pack sports muffler and 2 and 1/2 tail pipe. it should go good enough with the reco engine, what fuel is it running on/tuned to? get it tuned for 95/98 fuel and it will go better than the rubbish 91 fuel. Share this post Link to post Share on other sites
Falcor 5 Posted July 5, 2021 The cracks under the heat plateSent from my SM-N975F using Tapatalk Share this post Link to post Share on other sites
Falcor 5 Posted July 5, 2021 I'm running it on unleaded, I used to use the additive most times when filling up before the rebuild. It's probably meant to run 98 lolSent from my SM-N975F using Tapatalk Share this post Link to post Share on other sites
deankxf 20,231 Posted July 5, 2021 1 minute ago, Falcor said: The cracks under the heat plate Sent from my SM-N975F using Tapatalk cracked exhaust manifold? under the heat riser to the air cleaner snorkel. yeah they do that.. personally i'd try find a non cracked one or have it welded. extractors in My experience on stock engines make no difference to power, burn the accel cable, and cook the starter motor and also crack and rust Share this post Link to post Share on other sites
deankxf 20,231 Posted July 5, 2021 1 minute ago, Falcor said: I'm running it on unleaded, I used to use the additive most times when filling up before the rebuild. It's probably meant to run 98 lol Sent from my SM-N975F using Tapatalk if it's on 91 unleaded and it's not pinging(rattling noise) then you'll definitely pick up more power advancing the ignition timing and running 95 or 98.. usually you'll get better fuel economy on 95/98 and the cost saving to 91 isn't worth the difference Share this post Link to post Share on other sites
Falcor 5 Posted July 5, 2021 Ok, so sounds like I'll just try find another Iron head, hopefully there's one around. Are there any alloy manifolds that would fit, could this change how engine runs?To be honest I don't think engine has run 100% since rebuild, something wasn't right, just felt sluggish and sometimes had a flat spot... I need to troubleshoot as its probably something simpleSent from my SM-N975F using Tapatalk Share this post Link to post Share on other sites
Falcor 5 Posted July 5, 2021 I'm gonna run it on some 98 tomorrow, hopefully this makes some difference, only has a pissy stock Stromberg carby, I had a kit installed so it should be working fine, not sure if it's tuned properly thoughSent from my SM-N975F using Tapatalk Share this post Link to post Share on other sites
deankxf 20,231 Posted July 5, 2021 3 minutes ago, Falcor said: Ok, so sounds like I'll just try find another Iron head, hopefully there's one around. Are there any alloy manifolds that would fit, could this change how engine runs? To be honest I don't think engine has run 100% since rebuild, something wasn't right, just felt sluggish and sometimes had a flat spot... I need to troubleshoot as its probably something simple Sent from my SM-N975F using Tapatalk it's not the iron head that's cracked, it's just an exhaust manifold for an iron head engine(XC and XD early) the alloy head has different exhaust manifold due to bolt patterns. (XD late, to XF same ) won't fit your current engine flat spot could just be due to sitting ages, sometimes they come good, sometimes you'll need a kit in the carby again, it's likely just the accelerator pump part of the carby(need someone who knows what they are doing) if you can find a mechanic that isn't scared of working on old cars.. i'd just be saying, can you bump up the ignition timing a bit to suit premium 95 fuel and fix the flat spot.. shouldn't be overly expensive. . get the crack in the exhaust welded possibly by a GOOD exhaust shop Share this post Link to post Share on other sites
deankxf 20,231 Posted July 5, 2021 1 minute ago, Falcor said: I'm gonna run it on some 98 tomorrow, hopefully this makes some difference, only has a pissy stock Stromberg carby, I had a kit installed so it should be working fine, not sure if it's tuned properly though Sent from my SM-N975F using Tapatalk those carbys are fine, they go good with them still. i've had a couple 98 or 95 will only go better if the timing is set for them, so depends where it was tuned/set to Share this post Link to post Share on other sites
hendrixhc 10,918 Posted July 5, 2021 HAve you got any photos of the car itself? Share this post Link to post Share on other sites
Falcor 5 Posted July 5, 2021 I'll take a few more pics tomorrow Sent from my SM-N975F using Tapatalk Share this post Link to post Share on other sites
Falcor 5 Posted July 5, 2021 This is where she sits Sent from my SM-N975F using Tapatalk Share this post Link to post Share on other sites
hendrixhc 10,918 Posted July 5, 2021 NIce, looks fairly tidy. Share this post Link to post Share on other sites
deankxf 20,231 Posted July 5, 2021 Ha! i forgot I had one of these in a 302 for a little while about 27 years ago.. was too rusty for Me back then so i sold it only a few weeks after getting it. (briefly considered using the running gear for My XE S pack, but it was too slow) (brothers XB fairmont just to the side) Share this post Link to post Share on other sites
Falcor 5 Posted July 5, 2021 Yeah, that's awesome, sweet looking cruiser!! Love the picSent from my SM-N975F using Tapatalk Share this post Link to post Share on other sites
deankxf 20,231 Posted July 5, 2021 1 minute ago, Falcor said: Yeah, that's awesome, sweet looking cruiser!! Love the pic Sent from my SM-N975F using Tapatalk about 2 yrs later i bought a 6cyl one BRUSH PAINTED grey (XC fairmont) for $250 just for the 250 crossflow/c4 auto to put in My XD ghia after i took out a 351 for My XE.. had trouble giving it away and i don't think it was that rusty. times are a bit different now Share this post Link to post Share on other sites
