Server maintenance Read more... ×
SlowXh
Early rocker on a au head
Recommended Posts
Hay all  As the title says, I'm just wanting to know if the EA rocker fits on a au head.
Thanks
Different rocker ratios mate, they will fit, but your valves won't work too well...or do you mean rocker cover?
Sent from my S21 using Tapatalk
Share this post
Link to post
Share on other sites
Mate it depends on what the EA gasket is like, if it's the same as AU and the bolt holes line up, then the rocker cover should work.
But if your head is like mine on my ED/XG and has a half moon seal front and back, the rocker cover will only fit that type of head.
Share this post
Link to post
EA gasket is like ED/XG, it's the big flat wide one.
In EF they went to a skinny gasket and shaped the rocker cover to avoid having to use the half moons - basically cast into the rocker cover if that makes sense
Share this post
Link to post
Not all XG have the flat gasket.
Mine has the cast in half moons and skinny gasket set up.
I have a stack of flat rocker cover gaskets here from gasket sets that have the wrong gasket.
Must be early XG have the flat and late model the skinny moulded one.
Share this post
Link to post
XG probably changed to the skinny gasket when EF came out at a guess?
Share this post
Link to post
My XG XR6  had the flat EA type, but i've seen the other type
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
