SlowXh 5 Posted May 19, 2021 Hay peoples. This is my 1st post So I'm looking for information on putting a holley terminator X on a au motor. It's going into my xh 5speed Thanks Share this post Link to post Share on other sites
bear351c 10,270 Posted May 21, 2021 Hi, and Welcome. Can't really help with the Terminator X, theres a couple of videos on Utube, Skid factory, Dylan McCool, Vice Grip Garage etc who have installed similar. 1 SlowXh reacted to this Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted May 22, 2021 I've was looking into Holley Terminator X awhile ago thinking for Drag XE/XF sedan/ute with 5.0 windsor, maybe build as 347 & turbo with my built C4 auto (Terminator Max X can run 4L60/4L80 auto & smart tuner maybe able to setup to BTR Auto) also, & with suitable dual sync dissy & EFi mods will work on Cleveland & 429/460 Big Block, My thinkings AU engine would need to change to dissy with either stock EB-EL TFi or Holley's dual sync, Fox Body kit has adapter loom for plug in TFi dissy or don't use adaptor & plugs straight into Holleys dual sync, Or also MSD ?CDI 600? Coil pack per plug kit can be added as well if use Holley Cam sync instead. Holley have few vids on fitting to a fox body with both above kits, & KSR Performance & Fabrication did a bit of vid on setting it up the other day. like LSX idle motor is better then ford unit. 1 SlowXh reacted to this Share this post Link to post Share on other sites
