Phila 10 Posted April 28, 2021 Gday Just looking for some advice. Ive got an xd ute with a pretty tidy interior but i want to repair a crack in the centre console and the mounting points that are snapped off. I also want to repair the usual breaks in the side speaker grilles in the dash. So im looking for what glue will best fix this type of plastic? I will also do a bit of plastic welding to strengthen it Any advice is appreciated. Phil Share this post Link to post Share on other sites
bear351c 10,260 Posted April 29, 2021 Try Googleing "Q bond" used to repair Ford grilles etc, etc. Around the 3:00 minute mark. 1 roKWiz reacted to this Share this post Link to post Share on other sites
deankxf 20,233 Posted April 29, 2021 i'd try JB WELD.. i like it so far, but haven't tried it on many plastics yet 1 roKWiz reacted to this Share this post Link to post Share on other sites
Phila 10 Posted April 29, 2021 Ok thanks ill take a look at it. Share this post Link to post Share on other sites
Phila 10 Posted May 1, 2021 thanks to both of you for your advice .. they both look like good options .. ive bought the JB Weld 2 part urethane adhesive...see if that works... ive got a spare glovebox that im going to take cuts out of to make up reinforcing for the broken areas 1 1 deankxf and roKWiz reacted to this Share this post Link to post Share on other sites
deankxf 20,233 Posted May 2, 2021 cool, let us know what you think of them. Share this post Link to post Share on other sites
Phila 10 Posted June 18, 2021 Sorry its taken a while to respond, work etc gto in the way of things .. I bought the JB Weld. See the pics of the fix the JB weld smells same as Aryldite .. but im guessing its just a very good quality version of it .. if you are patient and leave the item alone for a few days after clamping its stuck like it was never broken here are some pics .. 1 2 bear351c, deankxf and roKWiz reacted to this Share this post Link to post Share on other sites
bear351c 10,260 Posted June 18, 2021 Excellent.! That has come up MINT.! JB weld and Araldite are similar products, both use a 2 part epoxy. Should be stronger than the original plastic. You could even epoxy a small piece of metal/alloy on the back of the plastic for added strength. 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,233 Posted June 18, 2021 yeah i'd have considered reinforcing if the dash part was solid but it might break next. i'd probably support it to the floor better. does look good though. Share this post Link to post Share on other sites
Phila 10 Posted June 18, 2021 4 hours ago, bear351c said: Excellent.! That has come up MINT.! JB weld and Araldite are similar products, both use a 2 part epoxy. Should be stronger than the original plastic. You could even epoxy a small piece of metal/alloy on the back of the plastic for added strength. theres actually 2 thicknesses of plastic because I wanted it to mount at the same 'level' so i made bits to fill the broken off areas then put now pieces shaped like original in front ... 2 deankxf and bear351c reacted to this Share this post Link to post Share on other sites
Phila 10 Posted June 18, 2021 3 hours ago, deankdx said: yeah i'd have considered reinforcing if the dash part was solid but it might break next. i'd probably support it to the floor better. does look good though. thanks .. there is a floor bracket and it mounts behind the ashtray .. ive also put a reinforcement on that because the whole thing was broken through the centre. It feels very strong now .. ive tested installing it and its fine ... Im just in the process of reinstalling the dash, after completely refirbing the heater and vacuum controls .. will post a pic(s) when im done 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,233 Posted June 18, 2021 i'll link you do the DASH REMOVAL thread in a minute, if you can put your 2 bobs in and fill in any blanks with photos (some got lost over time) that may be helpful in future Share this post Link to post Share on other sites
deankxf 20,233 Posted June 18, 2021 here's the thread i mentioned, if you wouldn't mind having a read, and seeing if anything needs a photo, that would be great. 1 roKWiz reacted to this Share this post Link to post Share on other sites
