burnsy 9 Posted April 16, 2021 Hi, I want to safely remove my rear torsion springs. when I release the arms from the 3 position adjustment lugs they go back and hit the shock mount supports and are still under a lot of tension. Not sure if anyone has tried this? My boot lid sits high at the window when closed, this is a boot lid of another car and has been fully smoothed on the underside so its probably my stuff-up ! I was hoping to remove the hinge arms cut out 5mm and reweld Thanks Burnsy Share this post Link to post Share on other sites
deankxf 20,266 Posted April 16, 2021 2 hours ago, burnsy said: Hi, I want to safely remove my rear torsion springs. when I release the arms from the 3 position adjustment lugs they go back and hit the shock mount supports and are still under a lot of tension. Not sure if anyone has tried this? My boot lid sits high at the window when closed, this is a boot lid of another car and has been fully smoothed on the underside so its probably my stuff-up ! I was hoping to remove the hinge arms cut out 5mm and reweld Thanks Burnsy i don't know if @MNTL.XD is still about, but I vaguely remember Paul doing similar on his XD, thread is below if you feel like checking it out regardless.. Share this post Link to post Share on other sites
2redrovers 21,390 Posted April 16, 2021 For a lot of situations it is possible to bend the hinge arms to get the alignment. This may involve some heat but I've used an F shaped lever to give you more power to bend the arms Share this post Link to post Share on other sites
bear351c 10,270 Posted April 17, 2021 Could cut the torsion springs off, and use gas struts out of an NF Fairlane boot..?? Share this post Link to post Share on other sites
burnsy 9 Posted April 18, 2021 22 hours ago, bear351c said: Could cut the torsion springs off, and use gas struts out of an NF Fairlane boot..?? Thanks, I don`t know why I didn`t think of that.... seems to be the way to go as the lid is also heavy because of the infill panels and bog so I could pressure struts to suit I will try and find a photo of the NL mounts. Thanks for all the suggestions. 1 bear351c reacted to this Share this post Link to post Share on other sites
