Mick.G 39 Posted March 27, 2021 I just wanted some reflection......Had to try first B4 i threw them, away Share this post Link to post Share on other sites
SPArKy_Dave 8,826 Posted March 27, 2021 I'd like to know where all the new genuine XF and XG headlights went? Even back around 2005's, it was impossible to find new XG headlights. I found one ONCE, but silly me didn't purchase it, as only one side. The XF and XG headlights, did have different part numbers - XF Assembly RH - XFN13005B LH - XFN13006B XG Assembly RH - EDC13005A LH - EDC13006A XF/XG lense - RH - XFN13011C LH - XFN13011D XF/XG reflector - RH - XF13118A LH - XF13119A XF housing RH - XF13H008A LH - XF13H009A XG housing RH - EDC13H008A LH - EDC13H009A Share this post Link to post Share on other sites
deankxf 20,231 Posted March 27, 2021 1 hour ago, Mick.G said: I just wanted some reflection......Had to try first B4 i threw them, away i'd definitely consider painting them again with the base coat paint before buying the repros..would be much cheaper and probably work better even if not as shiny Share this post Link to post Share on other sites
Mick.G 39 Posted March 27, 2021 Watched all those vi Dz , Yes seen all those video's ..would not not believe my mothers mouth Share this post Link to post Share on other sites
Mick.G 39 Posted March 28, 2021 Will try a base coat on the right headlight and if it is much better i will re do the left. 1 deankxf reacted to this Share this post Link to post Share on other sites
Mick.G 39 Posted August 4, 2021 Gave in and Bought after market headlight set , Changed the the glass len's so it still had the original glass. Was i little dull i thought at first , so got a new alternator also....Bright as a new set can be. Happy with the out come. Thanks again Gent's for you're input. 1 deankxf reacted to this Share this post Link to post Share on other sites
