David seagull 9 Posted March 10, 2021 Can someone tell me if the door key lock on a xh suit any other model as my one has broken off the plastic bit which the rod clips onto Just trying to find another for the drivers door Cheers Share this post Link to post Share on other sites
dvfalcon 352 Posted March 10, 2021 DGN with what the call the Tibet Lock will most probably be the same xf and earlier work differently c Dale Share this post Link to post Share on other sites
deankxf 20,287 Posted March 11, 2021 pretty sure XG and XH are same, but thats' all. they are different to XF and MAY be same as EF EL(even EB ED ) in some aspects(they have the lock in the door handle, but the back plastic bits might be same?) Share this post Link to post Share on other sites
deankxf 20,287 Posted March 11, 2021 JB WELD ? glue it back on https://www.jaycar.com.au/j-b-weld-epoxy/p/NA1518?gclid=Cj0KCQiA-aGCBhCwARIsAHDl5x9jQe_NpB5ZTOUE0Ng7u-eI6Lz08I8Mp1ZylIv885IuN_JxOxSQEQUaAuBoEALw_wcB Share this post Link to post Share on other sites
David seagull 9 Posted March 11, 2021 I did with loc super glue but it broke again Share this post Link to post Share on other sites
deankxf 20,287 Posted March 11, 2021 1 hour ago, David seagull said: I did with loc super glue but it broke again JB Weld can be drilled and tapped. it's amazing stuff.. depends where it broke and if you can have a massive blob around it to reinforce(i can't remember what's needed on that part) LOCTITE brand super glue isn't bad, but JB Weld is amazing if you have space for it Share this post Link to post Share on other sites
dex 2,065 Posted March 11, 2021 Kingswood Country have anything alike ,? could you post a pic of your broken one ,? Share this post Link to post Share on other sites
deankxf 20,287 Posted March 11, 2021 no idea what the quality of these are like.. might be able to just fit the plastic part? https://www.ebay.com.au/itm/Door-Lock-Ignition-Barrel-2-keys-Fit-For-Ford-Falcon-XG-XH-Ute-Van-1993-1998/324501420657?hash=item4b8dcaba71:g:8YEAAOSw2XJgO2a4 Share this post Link to post Share on other sites
SPArKy_Dave 8,870 Posted March 11, 2021 The plastic part is available separately from lock suppliers like LSC, I believe. https://www.lsc.com.au/Products/Locks/Automotive-Motorcycle-Bikes/Automotive-Motorcycle-Spares/ Share this post Link to post Share on other sites
