what wiring harnesses would be best for v8 conversion into a ed still retaining the interior components
1. what wiring harnesses would be best for v8 conversion into a ed still retaining the interior components
use diagrams and cut off nc ecu plug and solder the nl v8 ecu plug0
use full nl v8 harnesses and bcm but change plugs to make the ed dashboard and interior work0
use ed/nc harnesses but fit a au 5.0 ecu setup using a standalone harness0
