XCeed 205 Posted January 11, 2021 Hi All, I came across something interesting today, electronic distributors that you program the advance curve with your smart phone. https://progressionignition.com/shop/ols/categories/ford Thought this might be of interest as an alternative to say a 6AL-2 etc. I read somewhere they're manufactured in China but use US electronics with Apple/Android software. Anybody know anything about these? 1 gerg reacted to this Share this post Link to post Share on other sites
2redrovers 21,390 Posted January 11, 2021 Never heard of them before but looks interesting and they even have one to fit a rover v8 and the Ford 300. I like the anti theft bit. From the page... The Progression Ignition distributor is your all-in-one solution for high performance ignition. This HEI version is CNC machined from billet aluminum. Includes a 65,000 volt coil mounted in the cap.FeaturesIgnition timing is adjusted with your smartphone or tablet using the Progression Ignition Tuner App. There are NO mechanical adjustments inside the distributor.Easy to use! The app will create a custom timing table for you by entering just a few basic numbers.Tune with a modern style timing table interface. Powerful editing features for expert tuners but easy enough for a noviceMake timing adjustments in real time with the engine running or notStore as many tables as you want on the smartphone or tablet. Change tables instantly using the app.Theft prevention feature prevents the engine from starting using the app.Wireless Bluetooth connectionThe internal ignition module maximizes coil current to 8 amps up to 10,000 RPMBuilt in Rev Limiter2.5 bar MAP sensor for turbo and supercharged applicationsTiming range of 10 degrees BTDC to 50 degrees BTDCOne wire hookup just like a stock HEI Distributor gear is compatible with flat tappet cams (cast iron) and hydraulic roller cams (austempered ductile iron). Aftermarket billet steel solid roller cams will require a different gear. Some billet steel cams have a regular cast gear pressed on which is compatible. Check with the cam manufacturer. THIS PRODUCT IS LEGAL FOR OFF ROAD USE AND NON POLLUTION CONTROLLED VEHICLES (1965 & OLDER); HOWEVER, IT HAS NOT BEEN TESTED OR APPROVED BY THE CALIFORNIA AIR RESOURCES BOARD (CARB) FOR HIGHWAY VEHICLES IN THE STATE OF CALIFORNIA. BY PURCHASING THIS PRODUCT, BUYER AGREES IT WILL NOT BE USED ON POLLUTION CONTROLLED VEHICLES IN CALIFORNIA, OR IN A STATE WITH SIMILAR EMISSIONS REGULATIONS. Share this post Link to post Share on other sites
