SteveHobart 57 Posted December 9, 2020 Hey Guys What Vacuum Hoses/Outlets do I really need on a Crossflow? For mine, all I REALLY need is:- idle speed controller- Brake Booster- Fuel Regulator- Inside Air Controller So can I whittle down the Vacuum Outputs to these only and blank off all the others? Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
SPArKy_Dave 8,863 Posted December 9, 2020 For an EFI - all of them. and For a Carby running the stock 34adm - also all of them. Normally, they all work together as one happy family. I'm not familiar with the EFI hoses, but the carby ones relate to timing advance, throttle nudger on over-run, idle up/timing advance when Aircon is running, and other similar functions to prevent stalling. 1 macman reacted to this Share this post Link to post Share on other sites
SteveHobart 57 Posted December 9, 2020 Ah damnit. It’s just so messy! Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
macman 774 Posted December 10, 2020 Sadly they weren't just put there intentionally to look messy, funnily enough they all have a function You can start blocking things off (as someone did on my XD) but then things stop working! I can't think of any that I'd recommend removing. But I would recommend referring to a factory workshop manual or diagram to make sure everything's where it should be and then some clever routing and some cable ties or conduit can make things look a lot tidier. Share this post Link to post Share on other sites
