Luke13 56 Posted October 29, 2020 Hi all the next job on my xflow is putting the 4 barrel manifold and carby on can anyone help with what vacuum lines I will need and where to connect them to. And what vacuum lines and pvs I can remove when I take the Webber off.It was a auto but is now a manual Thanks Sent from my Pixel 3 XL using Tapatalk Share this post Link to post Share on other sites
Grimmy 312 Posted November 1, 2020 Is yours exactly as in the pics ? With working a/c ? Share this post Link to post Share on other sites
Luke13 56 Posted November 1, 2020 Yes but the AC isn't working but is exactly the same as in the pics. And I don't plan on fixing it Thanks Share this post Link to post Share on other sites
Grimmy 312 Posted November 3, 2020 Easy , get rid of all of it . How many hoses are coming out of the firewall ? you will need to hook up some of the hoses out of the firewall to make the dash controls work what distributor are you using ? 1 Luke13 reacted to this Share this post Link to post Share on other sites
deankxf 20,286 Posted November 3, 2020 On 11/1/2020 at 3:11 PM, Luke13 said: Yes but the AC isn't working but is exactly the same as in the pics. And I don't plan on fixing it Thanks if you are changing manifold and carby you'll only have a few things to hook up.. vacuum for the brake booster.. vacuum to the hose into the dash (runs the vents and stuff) the other hose coming out of the dash is heater tap. vacuum to the dizzy advance from a ported (becomes vacuum once the throttle is above idle) you should be able to connect the charcoal canister up somewhere but @gerg probably has a better idea on that. and the PCV valve is probably another you'd have to figure out with someone elses help. you could try replicate all those hoses for a stock look perhaps, but the carby and manifold probably wouldn't have enough outlets on it to even come close 1 Luke13 reacted to this Share this post Link to post Share on other sites
Luke13 56 Posted November 3, 2020 Thanks guys I will have still have the stock distributor should I be changing it thanks for all the helpSent from my Pixel 3 XL using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted November 3, 2020 Aftermarket Holleys don't come with a spark (dizzy vac) port do they? EGR I think yes (if 50-state legal)Sent from my CPH1920 using Tapatalk Share this post Link to post Share on other sites
