Luke13
250 crossflow AC bracket
I am replacing my water pump on my xe 250 crossflow how the hell do you get the AC bracket out of the way so I can install the new water pump
Thanks
Sent from my Pixel 3 XL using Tapatalk
Thanks
take the fan off and pulley? or unbolt the air con bracket on the engine block?
been a LONG time since i had an XE with air con
I Think I rotated the pump after unbolting it from memory when I've done on my XE's I know I didn't remove the bracket.
might have also pryed the arm on the bracket it foward just a tad as well.
When I did mine I saw no way other than removing the A/C compressor bracket. That said, I know there's a couple of variations of the mounting bracket (probably depending on whether it was factory fit, dealer fit or aftermarket?
I had to unbolt the compressor from the bracket, and then unbolt the bracket from the block before I could remove the water pump.
