roKWiz 900 Posted September 26, 2020 Just out of curiosity what does this PVS actually do, or is it just part of the choke setup. Share this post Link to post Share on other sites
SPArKy_Dave 8,863 Posted September 26, 2020 10 hours ago, roKWiz said: Just out of curiosity what does this PVS actually do, or is it just part of the choke setup. idle up, timing advance, fuel enrichment. some or all of those, depending on coolant temp. 1 roKWiz reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted September 26, 2020 Just out of curiosity what does this PVS actually do, or is it just part of the choke setup.It's to with AC I believe, because non AC carby cars didn't have it, and EFI didn't have it (because computer controlled all the stuff Dave mentioned) 1 roKWiz reacted to this Share this post Link to post Share on other sites
roKWiz 900 Posted September 26, 2020 9 hours ago, SPArKy_Dave said: idle up, timing advance, fuel enrichment. some or all of those, depending on coolant temp. No wonder mine runs like crap warming up in the dead of winter. Summers fine. and thanks Mr Polson 2 Outback Jack and SPArKy_Dave reacted to this Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted September 27, 2020 When I finally replaced my XF utes heater tap as it had a leak & didn't work found it was blocked solid, changed to new one & heater finally worked, till it split the heater core about 18mths later (which I still need to replace ), block off for thermostat housing is 3/8" (GAS), likes of supercheap have them in a blister pack on the stand with the trim clips & bolts packs. or if want to fit thermo fans later a Tridon TFS110 thermo fan switch will fit, 1 roKWiz reacted to this Share this post Link to post Share on other sites
