mcfly94 169 Posted May 11, 2013 Hey guys my rotor is all corroded went to replace it and cant get it off? How do they come off? Share this post Link to post Share on other sites
adrianphu123 73 Posted May 11, 2013 the rotor should just pull out of the top of the shaft. Share this post Link to post Share on other sites
mcfly94 169 Posted May 11, 2013 mm tips for a stuborn one then? Share this post Link to post Share on other sites
adrianphu123 73 Posted May 11, 2013 maybe a bit of WD40? i've never had a stubborn one before. Share this post Link to post Share on other sites
mcfly94 169 Posted May 11, 2013 i shall give that a go tomorrow! might even put the tie rod end puller on it and give it pull, think its the factory rotor. Share this post Link to post Share on other sites
Tyler06 266 Posted May 11, 2013 Had this heaps of times lol i just get a big flathead and use it as a lever on the side of the dizzy. Share this post Link to post Share on other sites
mcfly94 169 Posted May 11, 2013 yeah i tried that but i didnt want to damage the side plastic of the dizzy..ill give the wd ago and ill see if the puller works Share this post Link to post Share on other sites
dizzy616 183 Posted May 11, 2013 i had this. before i just yanked it off with a old rag and both hands Share this post Link to post Share on other sites
slydog 7,873 Posted May 11, 2013 Two blade screwdrivers resting on the dizzy body to lever it off.If your concerned sit a rubber sleeve or cloth over the plastic but it should come off easy enough.before you fit the new one wipe some anti seize/high temp grease on the shaft.Not much just enough to act as a lube... Share this post Link to post Share on other sites
Tyler06 266 Posted May 11, 2013 Two blade screwdrivers resting on the dizzy body to lever it off.If your concerned sit a rubber sleeve or cloth over the plastic but it should come off easy enough.before you fit the new one wipe some anti seize/high temp grease on the shaft.Not much just enough to act as a lube... U love the lube lmao ;-) 1 slydog reacted to this Share this post Link to post Share on other sites
mcfly94 169 Posted May 14, 2013 Holy shit i got it!, sprayed it with wd40. And then put l shape sheet metal bracket on the edge of the dizzy and tried to pry the old rotor off, eventually it snapped the rear of the rotor, but still didnt get it off. Then it snapped the front it off until the plastic cylinder was left, then i lifted the base black plastic and then put a flat plate on the dizzy internals and pryed the plastic centre piece of which also snapped off, man the thing was rusty as! Luckily it came of and theres a fresh new one on there Share this post Link to post Share on other sites
