XD Falcon ute
XD Falcon ute gearbox
Recommended Posts
Hi this might be a dump question, i bought my grandson a Xd ute it has a 3 speed auto column shift it's a project for the 2 of us my question is the young fella wants to put a 4 speed auto in can someone tell me what gearbox we need cheers
Share this post
Link to post
Share on other sites
4 speed will be a shifter & lever
Flywheel
Flywheel bolts
Clutch
Fork
Cable
Manual pedal box with clutch pedal
Clutch cable firewall mount bracket
Gear shift surround/tunnel housing
Manual console
Probably forgot something
Sent from my CPH1607 using Tapatalk
Share this post
Link to post
you won't need a 4 speed auto,  unless it's got lower diff gears(unlikely if it came as an auto will be 2.92 ratio.
if the 3 speed auto is good, leave it in there.(a stronger upgrade if you can find one is a C4 auto some of the 6cylinders had, rare even 10yrs ago)
4 speed autos are only on the overhead cam engines, different bolt pattern to the engine, and need a computer as they are electronic.  and wouldn't work well with the current diff ratio either. (they only had 3.08, 3.23/3.27) from memory.
it will sit on 2300-2400 ish rpm at 100kmh all day every day forever at that.
if you decided to modify it, then you'd look at a driveline from a donor vehicle(barra from BA onwards etc is popular these days.. but it's not easy and i wouldn't do it)
i'd stick with the crossflow personally.. good reliable SIMPLE engine, can change a starter motor in 4 minutes and an alternator in not much more time
Share this post
Link to post
58 minutes ago, gerg said:
Sorry I read that as "4 speed" and didn't see the auto bit. Disregard emoji849.png
i saw your post after i replied with mine, forgot to even mention it.. more info for the next person asking anyway
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
