Aussieyobbo16 7 Posted June 20, 2020 Looking to put a healthier low ks motor into the xg. Can I use any sohc motor with relative ease or is there a lot of difference in wiring and ecu. Likely looking at ef/el but possibly also au. Or would be better with just xg of eb/Ed Share this post Link to post Share on other sites
SPArKy_Dave 8,870 Posted June 20, 2020 Have you done a compression check on your current engine? Failing sensors, injectors etc, can also cause a loss in power. Share this post Link to post Share on other sites
Aussieyobbo16 7 Posted June 20, 2020 6 minutes ago, SPArKy_Dave said: Have you done a compression check on your current engine? Failing sensors, injectors etc, can also cause a loss in power. Yeah ive done a compression check. Havnt really checked any sensors. But there's a lot else wrong with the current one. Share this post Link to post Share on other sites
deankxf 20,286 Posted June 20, 2020 if you want to read a LOT... but learn a LOT.. this thread below is all you'll need probably. if you ask Me, the AU is too hard into XG due to the alloy sump.. (mate of mine did it, paid $400 for a TUFF MOUNTS Barra conversion sway bar..) then you still have to do the same mods as for EF/EF which is either use the serpentine belt setup or convert it to the V belts (EF onwards water pump outlet is smaller, so you need a custom joint in your radiator hose for that.. if you get an EB or ED (or even EA if they still exist.. 3.9, 3.9 was also in series 1 EB, which My brother thrashed the shit out of one to 400,000km and never had any issues other than a head gasket and dissy worn) if you do a compression test, and it's fine.. i'd consider not changing it.. unless it has worn bearings and other problems. depends on the budget also.. Share this post Link to post Share on other sites
SPArKy_Dave 8,870 Posted June 20, 2020 53 minutes ago, Aussieyobbo16 said: Yeah ive done a compression check. Havnt really checked any sensors. But there's a lot else wrong with the current one. What were the compression numbers? Share this post Link to post Share on other sites
