Aussieyobbo16 7 Posted June 19, 2020 Does the standard 4 speed auto from an au ute fit well in an xg without having to change much. The xg is 4 speed collumn Share this post Link to post Share on other sites
Thom 6,650 Posted June 19, 2020 Does the standard 4 speed auto from an au ute fit well in an xg without having to change much. The xg is 4 speed collumnYou will have to swap your xg bellhousing (The au bellhousing will bolt to the xg engine bit the bottom of the bellhousing won't mate up with the gearbox supports and unless the Au was also column shift it won't have the mounts for the shift selector), Speedo drive and gearshift indicator onto the Au box and it will go in 4 Outback Jack, gerg, Aussieyobbo16 and 1 other reacted to this Share this post Link to post Share on other sites
Aussieyobbo16 7 Posted June 20, 2020 is the yoke for the tailshaft anydiffent Share this post Link to post Share on other sites
deankxf 20,287 Posted June 20, 2020 1 hour ago, Aussieyobbo16 said: is the yoke for the tailshaft anydiffent tailshaft yoke all the same 1 Thom reacted to this Share this post Link to post Share on other sites
