mcfly94 169 Posted May 10, 2013 Hey guys im looking at replacing my standard coil with a msd blaster 3. Can get for $90. Is it any good? Share this post Link to post Share on other sites
xeeclipse 37 Posted May 10, 2013 save yourself the money and get a near new ef-el BOSCH coil from the wreckers. mounted on the strut tower away from any heat soak it works a treat. Share this post Link to post Share on other sites
mcfly94 169 Posted May 10, 2013 are they better? i wanted to retain the standard mount or should i mount away from the block Share this post Link to post Share on other sites
Mr Polson 10,214 Posted May 10, 2013 Didn't EF have coil packs? Share this post Link to post Share on other sites
Thom 6,650 Posted May 10, 2013 Sure do have coil packs El doesn't Share this post Link to post Share on other sites
adrianphu123 73 Posted May 10, 2013 I got my blaster3 for 60 bux, so 90 is a bit steep. I replaced my leaking stock coil with one and its working fine. The only thing is, they dont fit in the standard crossflow coil bracket, I had to make one up. Share this post Link to post Share on other sites
mcfly94 169 Posted May 10, 2013 I got my blaster3 for 60 bux, so 90 is a bit steep. I replaced my leaking stock coil with one and its working fine. The only thing is, they dont fit in the standard crossflow coil bracket, I had to make one up. alright, well that was ebay, ill check out a local speed shop. Bracket is easy to make up Share this post Link to post Share on other sites
