Tymat 2 Posted April 19, 2020 Howdy My ftrucks auto wont go into drive from 2nd. every other gear is fine . Its jumping into a neutral. Its a cross flow 250 TIA Share this post Link to post Share on other sites
gerg 10,871 Posted April 19, 2020 Probably needs a linkage adjustment, has a worn linkage or bush, or the selector detent is wornSent from my CPH1903 using Tapatalk Share this post Link to post Share on other sites
deankxf 20,286 Posted April 19, 2020 not low on fluid? that would be all i'd expect if park and Reverse etc are in the right spot. Share this post Link to post Share on other sites
Tymat 2 Posted April 19, 2020 The fumes have increased and not great on idle also . Thanks for your input Share this post Link to post Share on other sites
Tymat 2 Posted April 19, 2020 Thanks all . It was a split in a small vacume hose under the air filter . Only small . 2 bear351c and deankxf reacted to this Share this post Link to post Share on other sites
